Special tool for removing gauge needle?
Ok, I like the looks of my white face gauges, but one thing really annoys me. Whoever put them on (stickon type) did not line up anything and they are about as cheap as they come. In the daytime I can see through them to the old numbers behind and they have some serious bubbles. I want to remove them. Would I need a special tool to remove the needles? I know to make note of exactly where the needles are. I figured I'd remove each sticker one at a time and reinstall the needle before moving to the next one. I do want white faced gauges, but not these el cheapos. So for now I'm wanting to go back to stock until I get my reverse glow gauge faces...
Any suggestions or pointers? If you know where there is a tech article for this, please lemme know. Thanks!
RE: Special tool for removing gauge needle?
I would buy a set off guages from upr, and slide those over your current set up. I have the silver reverse glow gauges and reall like them. You don't have to take the needles off to put the upr ones on. Here is the link: Gauges You cant see through them and it would solve your problem.
The needles just pull right off. Do yourself a favor. When you go to put everything back together, just plug in the cluster and start your car, wait for it to idle and get to operating tempature and make sure all your needles are where they're supposed to be. That's the best way to make sure that everything is lined up and reading right. And then you can put the glass back on and screw it into place.
You can use a fork to pop off the needles. Take a pic of your gauges so you can reinstall them correctly (with the car running and at temp). The speedo is a bit harder. You can leave the clear plastic off and drive on the freeway next to a friend and set the cruise control and have him tell you your speed and put the needle back on.
do what i did... find a Bullitt gauge cluster off of a salvage yard site and switch the guages off of your stocker so the PATS system doesnt freak out. it looks bad ***... you can even do the same thing with the cobra white faced gauges, except you would have a higher redline
Well, I have to remove the white faces that are on there now before buying anything else to install over them. I do like the reverseglo gauges. My cousin Im starting to find out is an idiot, I think. He said he bought the entire cluster because it is a Saleen cluster. But it doesnt say Saleen anywhere on it, and the faces are bubbled up bad and not lined up at all. Plus if they were Saleen factory gauges, you wouldnt be able to see behind them. And since the faces arent lined up right, the needles dont read right. Luckily I can see through them and can tell the true readings. I think I'm just going back to stock for now until I can get some more. Can I remove the speedo one without messing anything up? The speedo is off anyways due to my gears. I know my mph by rpms.
One thing i need to know is, if I do install the reverse glo faces, my needles still light up right? It's showing no lights in the pic for the needles and that sucks.
They will still light up red
ORIGINAL: lookin4astang
They are a pain to line up again. As mentioned earlier, use a fork to pry off the needles. Make sure that your car is warmed up before you take off the needles so that all the needle placement is at its standard spot at an idle. switch them up, wire them in, and place them back in. It may take a couple trys to get the rpm and speedo needles perfect again. I had to have one of my buddies clock me with a radar gun to make sure my speedo was right,lol.
ORIGINAL: 03mustgt
The directions on their website say that you need to remove the needles in order to install. Were you able to do it without removing them? I really like the white look! Also what is the difference between the 'reverse glow' and 'EL Glow' on their a/c faceplates? does anybody have these? any pics??
