swaping the 2v
swaping the 2v
ok here is my ? how hard or how much in labor would it be for swaping my 2002 2v to a mach 1 engine my friend is selling me his engine with like 50 somethin k and the tranny how hard or is it even posible right now its a stock 2v auto going to a mach 1 standard trans
RE: swaping the 2v
ORIGINAL: sleeping stallion
RE: swaping the 2v
if you do it yourself it should be easy man the engine is just a direct swap bolt it right in youll just have to go to a junk yard or what not a buy a new shfter bezel or whatever the hell it is called so you can ditch the gay auto shifter for a shift boot and then get the clutch pedal assembly out of the car also ....that should be all youll need assuming the engine will come with the ecu and harness ive read you can use the gt ecu with tuning and the harness with extending a few wires here and there but if you pay for this to be done i could only imagine you paying anywhere from 1500-2000 for labor and miscellaneous parts and crap youll need
RE: swaping the 2v
I think if you can get a shop to pull the existing engine/trans, put the 4v in, tune it properly, and then swap your auto trans for a manual, your gonna be real lucky to get away with a 2k install.
How much does your friend want for the engine/transmission. The mach 1 cars are not THAT much more expensive now, and you would have the looks and the rest of the goodies if you just buy a mach 1.
RE: swaping the 2v
You can get cobra pull-out motor on ebay for 4-5 grand. Much stronger short-block than the Mach 1.
Seriously though, if you're going to spend that much money, just get a Cobra if you want big power.
RE: swaping the 2v
ORIGINAL: laserred38
how much is he selling the motor/tranny and where is he located???
RE: swaping the 2v
hey thanks for the advice but the cobra engine is really what i want but dont have that money he said he would give me everything except the body for 1500 nothing is wrong but i guess he is swaping his engine too but i guess my main ? was can it be swap with out modifying the body or anything will it fit right in there just drop it in and set it up. oh i really im thinking about this becuz he said i can give him payment so that was a big help
