Blower motor not working - 98 GT
RE: Blower motor not working - 98 GT
Do a continuity check and make sure you are getting power to the motor itself. If you are getting power to the motor then chect the motor itself and make sure you have current traveling from point A to point B.
Just to add to what has been said already. Make sure it doesn't work at any of the fan speeds, if it doesn't then yea the motor is prolly bad. Just so you know, if you are going to replace the blower motor yourself, they don't always come with the squirl cage(fan) so donn't break it when you take it apart. If it does come with one then by all means break away,
Have you checked to see if it might just be stuck? I had an issue with something like this once in my Blazer. Turned out something fell into the blower and wedged itself between the housing and the little mouse wheel looking fan..
Just an idea.
Just an idea.
