Comp Cams
RE: Comp Cams
All cams need to be degreed so you know were you valves are in relation to opening and closing becayse of todays tolorences cams can be off as little as 1 degree. plus there is benifit to degreeing a cam if it off from specs!!
RE: Comp Cams
depending on the size of the cams you'll need valve springs. i have vt stage 2 cams with the stock heads. i eventually plan on P&P the heads and building the bottom end over the winter. if and when i get to it this winter the gains will be better and i can rev the **** out of it to where i will be making peak power with the stage 2's. and i can run a bigger shot but my ultimate goal is for it to some boost from TT's
junior04
09-28-2015 10:53 AM
