clutch fluid
RE: clutch fluid
It's right there next to the resevoir for the blinker fluid and headlight grease.
Whatever you do, don't use brake fluid. You definitely want to use headlight grease, though someone on here will disagree, thinking battery bearing oil is better. Don't believe 'em.
FYI....Your Stang has a cable activated clutch.
ORIGINAL: Black on blacK
where is the resovior for the clutch fluid? does it just take brake fluid or is it something else?
RE: clutch fluid
ORIGINAL: Colorado_Mustang
Haha that was pretty funny. It uses a clutch cable and not hydrolic fluid and I was reading somewhere that the cable assebly should actually be checked as part of routine maintenance. It's on the firewall.
jwog666
12-27-2021 08:09 PM
junior04
09-28-2015 10:53 AM
09-25-2015 06:42 PM
