How much Nitrous is safe?
On a stock 2V, how much Nitrous can be used at once and not blow anything? Would the timing need to be retarted or colder plugs needed? I was thinking about the NX EFI plate kit. How much would it apx cost to have installed?
RE: How much Nitrous is safe?
Honestly it kind of depends on the shape your motor is in .. you can run a 75 wet shot all day .. I'd feel comfortable running a 100 all day .. just from experience.. I wouldn't go over 125 in any circumstance unless you have the funds to rebuild the motor in the unfortunate cirumstance .. it blows ..
I'd def. go with a zex or NX kit .. you'll want a bottle warmer and purge .. basic setup .. have your guys run a Wide open throttle set up with a window swtich .. and before you start spraying .. have them get it dialed in ...
You can expect to pay around 120-180 dollars .. ( 3 billable hours of install at an average 60 dollar an hour rate ) for the installation labor alone ...
well you should be fine to run a 100 shot stock for now .. but honestly its whatever you feel comfortbale wtih .. i just know i wouldn'y push that stock block too far with juice ... and you could drop a couple degrees on the spark plugs ..
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
