How much Nitrous is safe?
Old 11-07-2006, 04:05 PM
03 GT
03 GT's Avatar
Default How much Nitrous is safe?
On a stock 2V, how much Nitrous can be used at once and not blow anything? Would the timing need to be retarted or colder plugs needed? I was thinking about the NX EFI plate kit. How much would it apx cost to have installed?
03 GT is offline
Old 11-07-2006, 04:18 PM
akelemecz
I ♥ Acer
akelemecz's Avatar
Default RE: How much Nitrous is safe?
Honestly it kind of depends on the shape your motor is in .. you can run a 75 wet shot all day .. I'd feel comfortable running a 100 all day .. just from experience.. I wouldn't go over 125 in any circumstance unless you have the funds to rebuild the motor in the unfortunate cirumstance .. it blows ..
I'd def. go with a zex or NX kit .. you'll want a bottle warmer and purge .. basic setup .. have your guys run a Wide open throttle set up with a window swtich .. and before you start spraying .. have them get it dialed in ...
You can expect to pay around 120-180 dollars .. ( 3 billable hours of install at an average 60 dollar an hour rate ) for the installation labor alone ...
akelemecz is offline
Old 11-07-2006, 04:24 PM
03 GT
03 GT's Avatar
The engine has 30,000 miles on it and uses synthetic oils only
03 GT is offline
Old 11-07-2006, 04:28 PM
akelemecz
I ♥ Acer
akelemecz's Avatar
well you should be fine to run a 100 shot stock for now .. but honestly its whatever you feel comfortbale wtih .. i just know i wouldn'y push that stock block too far with juice ... and you could drop a couple degrees on the spark plugs ..
Old 11-07-2006, 05:50 PM
04GTMustangRob
04GTMustangRob's Avatar
I am running a 100 shot and i have the NX EFI system. You will need a good tune though.
04GTMustangRob is offline
Old 11-07-2006, 06:39 PM
lxl 02 GT lxl
lxl 02 GT lxl's Avatar
100
lxl 02 GT lxl is offline
guitarman376
09-30-2015 05:54 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
v8sn95
09-07-2015 10:17 AM
Sandmanbjj
08-21-2015 12:38 PM
Quick Reply: How much Nitrous is safe?
