H&R springs
RE: H&R springs
I got mine at tirerack, it was the cheapest i could find and i looked around quite a bit, plus tire rack is awesome with customer service and shipping. If you want more drop than 1.5" get the SuperSports (1.75/1.6" drop), i LOVE mine!
RE: H&R springs
ORIGINAL: OnyxCobra
RE: H&R springs
oh i see, well either will look good. i think the sports are a 1.6/1.5" drop. Everything ive heard from people say they usually scrape with the Sportlines but not with the H&R SS's. but if u want it higher the sports would look good too.
RE: H&R springs
ORIGINAL: OnyxCobra
RE: H&R springs
Yeah i understand what you're saying. So its your prochamber thats scraping... the difference is the H&Rs hold the rear of the car up higher than the sportlines, .4" higher, not to mention the front is higher also, but it looks similar. I cant say though b/c ive never had sportlines, its just what ive heard. How much does it not clear by? If you need a little extra height you could try some polyurethane spring isolators front and rear, if you're barely clearing that might give you enough clearance.
Also, when you tightened down your prochamber, did you jack up under the thing first before tightening it or did you just put it up and tighten it down? If you jack it up first it gives you a lot more ground clearance, just a thought.
RE: H&R springs
1. ya im just scraping by a little going into the garage but in tother places with like 2 ppl in the car it scrapes bad on the speedbumps
2 no i didnt try jackin it up before tightening but i still scraped in some places before i put the prochamber on so i think ill go with the SSs
RE: H&R springs
uh yeah there is a pretty dramatic difference in both springs.. i have been debating the matter for like 4 months now. its crazy.. im torn between the two even tho the sportline drop is like PERFECT??? how is the performance and output of the sportlines?? do they bogg your launches or what-- are they better launching then stock?
the h&r's supersport drop is nice, just not enough for me, yet the springs are really good with launching from what i hear??
lastly, your sportlines-- hows the ride quality when just cruising??
RE: H&R springs
i think the H&R SS is a better drop than the Sportlines. To me the sportlines make the back look too low, I think stangs need slightly more drop in the front. I dont have any personal experience with the Sportlines but from everything ive heard im going to say the H&Rs are way better springs. I've heard the sportlines have stock spring rates, which isnt the best when your car is lowered 2". I've also heard Sportlines are bouncy, etc. I was parked next to an SN95 with sportlines and the front was almost identical height.
