SHIFFTING PROBLEM!!!!!!!!!!
I have a 2004 mustang gt rebuilt and whenever I switch from first to second, the rpm drops down below 1000rpm and makes this weird noise and stops after I accelerate, I was wondering if it mattered if the rpm's drope below 1000rpm after shifting? thanks
RE: SHIFFTING PROBLEM!!!!!!!!!!
I switch 1st at 1300rpm and was wondering if it was because I wait untill i let go of the clutch fully before I accelerate, does it matter if i accelerate while the clutch is in? thanks
Whenever I shift at hight rpms at jerks a lot, should i hold the clutch in a little bit while accelerating when shifting from 1st to second, or what can I do to stop the jerking at higher rpms, without wearing out my clutch? thanks
ive got another question that also has to do with shifting ive got a pro 5 shorst shifter in my cobra and when i try to power shift from first to second i grind like no other is it because my timing isnt right or what ive tried it over and over and no success it seems like i have to delay to get a clean shift at least when im trying to shift quickly like at the track etc.. any help
let off the clutch a little easier, you'll allow the drivetrain and engine to catch up to each other, sounds like your poppin the clutch...just take off from first, foot off gas, put the clutch in, put it in second, and let off the clutch then gently press the gas...but if you hold the gas down you'll power shift which will burn a clutch, it takes some getting used to
check your tranny fluid, you having trouble getting it outta reverse sometimes?
ORIGINAL: 98cobratx
