02 SENSOR - MustangForums.com
02 SENSOR
Old 08-16-2004, 01:39 PM
stonemonk9
Default 02 SENSOR
ok, so i was puttin my x pipe back on, and i noticed the wires comin from one of my o2 sensors was ripped, and also my check engline code was for two of my o2 sensors, so i call ford and i find out that they are 101.02$ (wat a wierd price?!) thats ridiculous, are they even worth replacing?? or does anyone know of cheaper ones?
stonemonk9 is offline
Old 08-16-2004, 03:16 PM
rtm
Default RE: 02 SENSOR
How close to the sensor was the break. I would check to see if you can repair it yourself. It could just be a simple splice job.
Todd
rtm is offline
Old 08-16-2004, 03:28 PM
Acer2428
Site Mod
Acer2428's Avatar
Advance has them for $80........ Still, that's a lot of money. Almost pays to get MIL ELIMS..
Acer2428 is offline
Old 08-16-2004, 10:29 PM
tarpymac
mills i what you need i had to put the on 98 gt with off road h pipe. if it is to short the just splice them no prob.
[IMG]local://upfiles/6083/CE8E036B5B564856ACAC3B9751043962.jpg[/IMG]
[IMG]local://upfiles/6083/AECDE287392F40EEBB67376F4E01D500.jpg[/IMG]
tarpymac is offline
Old 08-16-2004, 11:41 PM
stonemonk9
wat exaclty is a mil and the break in the wire is comin right outta the sensor i tried splicing it and shovin it in, but no luck. also wen i start my car occasionally itll blow some smoke, and i was also told that the sensors culd be the cause of that and that if there defective they can rob u of power. is that so?
Old 08-16-2004, 11:53 PM
mdvaldosta
I ♥ Acer
If its the rear o2's (on the mid pipe) then they dont do anything other than setting of your check engine light if your cats arent working properly. The only ones that effect your a/f is the front ones. A mil eliminator extensions just keep your light from coming on and you only use them on the rear
mdvaldosta is offline
Old 08-17-2004, 12:51 AM
jdaniel
I ♥ Acer
MIL stands for Malfunction Indicator Lamp.
jdaniel is offline
Old 08-17-2004, 05:18 AM
stonemonk9
ok, kool, by the way i dont have cats, so do u guys think i shuld spend the money on em or screw it?
Old 08-18-2004, 05:21 PM
jishead
If I am understanding your correctly your o2 is broke in such a place that you can't repair it and you don't have any choice but to replace it. Although that rear o2 is only used for CEL (check engine light) and not air / fuel computations, I think that you still have to have an o2 sensore in the bung in order to even use a MIL right? Even my prochamber has o2 bungs for the o2 sensor. The computer takes the switching rate of the rear divided by the switching rate of the front o2's and it should be within a certain ratio (the rears should switch slower because they have been cat'd). If they do not switch slower then your CEL comes on. If youCEL comes on you can make MIl (RC circuit) to disable the CEL from coming on.
I can see where repairing the o2 would be a problem. I've only made 1 MIL (different car) and those wires were alluminum and very hard to solder to other metals.
If I am wrong about this please correct me but I don't see any choice but to replace your broken o2 sensor.
jishead is offline
jwog666
01-07-2018 07:16 AM
Dathan
10-05-2015 05:52 AM
mrtrodonet
09-29-2015 11:13 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
TfcCDR
09-14-2015 12:08 PM
Quick Reply: 02 SENSOR
Featured Sponsors
