SO i have 100,000 miles now. Along with new air filter , Plugs and wires , seafoam and draining the radiator , what else can I do thats not to expensive?
engine oil, tranny oil (filter if auto), diffy fluid, fuel filter, brake bleeding, tire balace/rotation (if u can), clean the battery and make sure everything is snug/tight, double check coolant hoses for wear as well as accessory belt...um...check steering for leaks or broken boots, double check all bushings for excessive wear...um...double check your pcv system, or seafoam the intake because of the excessive build up you've probably built up...thats all i can think of[&:]
