70 mm or 75mm throttle body?
11-13-2006, 02:34 AM
I need help! i have a 2001 gt with a blower and long headers, wich size throttle body will work the best? 70mm or 75mm Accufab
11-13-2006, 03:04 AM
RE: 70 mm or 75mm throttle bodie?
what all been done to the motor
11-13-2006, 03:06 AM
You'll get a lot more responses in the 4.6 forum. Also, this is discussed about once a week, if not more, so there is already a ton of info posted on this
11-13-2006, 07:51 AM
Blower means bigger and less restrictive is better. But it can be worth, depending on heads and intake (i.e. other bottle necks).
What you should really be doing is upgrading your pistons. Stock pistons are cast and tend to go south under pressure.
11-13-2006, 10:30 AM
welcome to the forums! post in the 4.6 forums
11-13-2006, 04:16 PM
75mm
11-13-2006, 06:00 PM
go with the 85 mm
11-13-2006, 06:05 PM
i would go with 75mm. i dont think you can go TO BIG , i dont see how over doing it would ever hurt.
11-13-2006, 06:53 PM
Intake components are like the exhaust system. Going too big CAN in some instances hurt you.
11-14-2006, 12:40 AM
stock motor
