is this true?
#21
RE: is this true?
UDP's wont affect anything unless you have an dry sump system and an oil pump thats driven off of a belt. Even on the 302's, the oil pump is driven by the distributor, which is driven by the cam which is driven by the crank via a chain. So I dont buy that underdrives will "dry up" an engine, unless its dry sump.
-P.
-P.
#22
RE: is this true?
If Ford Racing sells underdrive pulleys, I seriously doubt they will cause any kind of engine damage. A bad install may, however. Simply run synthetic oil and you'll never worry about any such oil related problems again. Royal Purple all the way baby....crankcase, tranny and rearend. Only way to fly!
#24
RE: is this true?
UDP's are over-rated and sold to millions due to that fact.
First off slowing the belt driven accessories down frees up power it doesn't add it.
Doing so can cause issues with the power steering running and the charging system spinning slower.
I myself ran only a UD pulley on my water pump with my GT. The WP can take a little less RPM.
Another thing to think about is that the rubber dampner on the crank pulley went through extensive testing to cancel out harmful engine vibes. The new pulleys that have the dampner still allow certain amount of harmful vibrations. You cannot feel a difference but there is one.
#29
RE: is this true?
ORIGINAL: cody6.0
And I'm pretty sure Steeda does plenty of research to make sure the balancer does not put out any vibrations. Other company's maybe not so much but there is no way Steeda is going to have their name associated with something that will blow up your engine
#30
RE: is this true?
Motoblue makes a water pump pulley available by itself. And yes it's bigger thus the reason it under drives the WP.
The water pump is the only thing I feel safe under driving since it isn't short of pumping power even when under driven.
As for other peoples SFI approved crank pullies yes they may put research in but they aren't as good as a stock dampner.
