i need some help folks
so im trying to remove the fuel tank on a 96 gt. i have some questions. 1)must the gramet be cut to remove the neck? 2) where and what do i need to disconnect? 3)how much are new fuel and vapor line clips from ford (OEM)? and 4) is silicone sometimes used between the filler neck and gramet. (im haveing trouble removing the filler pipe from the car so that i can pull it out with the tank.
RE: i need some help folks
check inside the fender too...i dont think u need to cut anything
oh make sure to relieve any fuel pressure before u drop the tank or remove any lines, and disconnect the battery to be extra sure
08-14-2015 12:27 AM
