Swapping taillights, need help!!
RE: Swapping taillights, need help!!
Pop your trunk and there are studs that are attached to the tailights. Get a socketa and unscrew the bolts. I believe there are 4-5 bolts per taillight. Put the new ones on and put the harnesses to the correct location. You should find it very easy once you get started.
Pull away the expensive truck liner. Locate the 4 stubs with little nuts on them. Undo the little nuts pull taillight away from car unplug it. Reversal for install. Check your blinker fluid while your back there. Now crack open a beer because you just spent 2 minutes working on your car
Matt's 95 Stang
10-05-2015 07:16 AM
