New Mustang Owner ?'s
When I am in 3rd gear, and am at about a steady 3000 RPMs, my rear end feels as if its going over little bumps. However the road is completely smooth. Any ideas?
Also when I am about 3000 RPMs (In any gear, and even revving it up) I hear a whisteling noise. It sounds like its either my BBK air filter, or my stick shift. Any Ideas? How can I stop this sound?
RE: New Mustang Owner ?'s
um...start with the basics, double check tire pressure, when was the last time u had them balanced...push down on your car and if your car bounces alot you may have bad shocks in the rear, i doubt its axle rap...as for your whistling, take off the cover around your shifter (get one one end and give it a slight tug, toque clips) and check the grommet, if not make sure all your door seals etc are in tact and not cracked
Noises could be anything, you have a short throw shifter? transmission noise gets louder with after market shifters, is your rear end whining? maybe the previous owner had a bad installation... jack up the rear end and put it in 5th gear and see if it makes any noise... could be a number of things.
Also is this normal for my year? My car in 5th gear does 60 at about 1600 RPMs. Seems like I always have to be in 4th unless I am on the highway.
Not positive on this, but all I know is that i don't use 5th inless I am going downhill or going 70+.
ORIGINAL: lVlustang
