caster/camber plates
Old 11-15-2006, 02:04 AM
PushinTheLimit
PushinTheLimit's Avatar
Default caster/camber plates
Can someone enlighten me on what these do? I've been researching where some goes go with some lowering springs and then they'll do caster/cambers. I'm thinkin that since the springs offset the balance on the lower than stock, which in turn causes the camber to react differently with the tires. Meaning that it will cause more wear on either the inside or outside of the tire. Do the caster/camber mods balance this out so to say?
PushinTheLimit is offline
Old 11-15-2006, 02:06 AM
trance565
trance565's Avatar
Default RE: caster/camber plates
yes, basically, when you lwoer the car a certain amount, the wheels will bend inward at the top, so you ahve to get teh caster camber plates, inorder to bend em back out and make them level.
trance565 is offline
Old 11-15-2006, 02:42 AM
crulee
crulee's Avatar
I want to know with what springs are they required or with what drop is it required. If I lower only 1" do I still need them ?
crulee is offline
Old 11-15-2006, 02:44 AM
sitnlopro99gt
sitnlopro99gt's Avatar
you only need them if you drop lower than 1.5" you will be fine with the eibach prokit etc. do some searches on the site alot of your questions will already be answered.
sitnlopro99gt is offline
Old 11-15-2006, 03:47 AM
geetee03
geetee03's Avatar
i have the pro-kit and c/c plates, i also had to get camber bolts to align it properly.
geetee03 is offline
Old 11-15-2006, 03:55 AM
trance565
trance565's Avatar
1.5+inch drop, you will 99% chance need the plates, only person i know that didnt, and this amazes me, is kadence. either A. his **** is magic, or B. he's got a custom plate that isnt adjustable. we cant figer it out
Lethaldosage423
10-19-2015 12:12 AM
Explosive
10-02-2015 07:45 AM
mdg
10-01-2015 07:04 AM
winner99
09-30-2015 07:04 PM
maestro1024
09-21-2015 02:40 PM
Quick Reply: caster/camber plates
