tranny question
tranny question
has any one has this problem with the tranny that when is cold or the car is cold the 1st to 2nd gear kind of grind not the hard but alittle well not grinding but sometimes pops out and the shifter shakes and when it gets hot is like new no problem at all
RE: tranny question
I am sorry, but you didn't answer in the form of a question!
Puncuation please!!
So your problem is that when it is cold outside, shifting from first into second makes a grinding noise. Also, occasionally, it just pops out of gear?
Is that accurate?
-Nicholas
Puncuation please!!
Is that accurate?
-Nicholas
RE: tranny question
Mine grinds when cold a little, but is fine when warmed up. Nature of the ATF filled manual tranny (even my F250 transmissions do this). I've never had one pop out, and that sounds like the TSB that was released from Ford...or you're just not getting it all the way into gear.
ORIGINAL: 03dgsgt
RE: tranny question
Mine was the same way. I have the 3650 tranny which has a TSB on the synchros. Before I got mine replaced, I changed the fluid to Royal Purple Synchromesh and only filled it up to 3.25 quarts (recommended by Tremec in the TSB) and my problem went away. You could try changing the fluid, it may help ya out....
treesloth
09-28-2015 07:03 AM
