Few questions regarding SQ Trim?
Old 11-20-2006, 05:38 PM
97stanger
97stanger's Avatar
Default Few questions regarding SQ Trim?
I am starting to gather some other parts for my 97 Gt before the spring comes so i can have this car running pretty good. I currently have full bolt ons, and recently ordered a SQ trim Mongoose Kit, plus a boost pipe. I am also planning on doing a PI Intake Manifold. I have two questions:
1) Do/Should I get a vortech mini race bypass valve for my SQ trim, which is going to be running between 9-10lbs?
2) About some cams for my car...I am going to keep my stock non pi heads, for compression reasons. I was wondering if there are any good cams out there that are good for s/c setups and non pi heads. So far the best ones i have found are the Crower Stage 2 NPI S/C cams...any input? Are these cams even worth it? Can i even do a stage 2 setup on my car?
97stanger is offline
Old 11-20-2006, 06:04 PM
LvGordo
LvGordo's Avatar
Default RE: Few questions regarding SQ Trim?
call Scott at VT.
LvGordo is offline
Old 11-20-2006, 06:07 PM
97stanger
97stanger's Avatar
yah, i think thats what im gonna do is just call....but does anybody have any input on the mini bypass for my setup?
Old 11-20-2006, 06:12 PM
LvGordo
LvGordo's Avatar
ORIGINAL: 97stanger
i would love to hear the fssht! too when i shift
let us know what you find out.
LvGordo is offline
Old 11-20-2006, 07:02 PM
97stanger
97stanger's Avatar
where can i get the mini race bypass valve?
Old 11-20-2006, 07:14 PM
Sap
Sap's Avatar
1). Yes, you should get the bigger bypass valve as the bosch one wont handle 9-10lbs
2). MPH has blower cams you should look in to....
E.
Sap is offline
Old 11-20-2006, 08:07 PM
gsxrstang69
gsxrstang69's Avatar
Ask these questions on the MPH forum. They have all the answers to your problems.
gsxrstang69 is offline
Old 11-20-2006, 10:46 PM
97stanger
97stanger's Avatar
nobody seems to answer over there...
regarding the mini rave bpv:
I've heard mixed things, ive heard that the stock bosch one can handle 9-10 lbs, and ive heard that i need to get the bpv...so im not sure which route to go
regarding the cams:
I'm thinking i might either go with Crower Stage 2 non pi s/c cams, or just give mph a call and see if they can custom grind me a set.
any feedback is appreciated guys
GimpyHSHS
19
12-19-2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mdg
10-01-2015 07:04 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: Few questions regarding SQ Trim?
