MGW shifter HELP!!!
RE: MGW shifter HELP!!!
yes that bushing needs to go back on the new shifter just like it came off the old one. i doubt having a 3650 tranny makes a difference. it should say so in the directions, but yes mine said it MUST go back on!
It not hard to put in. Just get one side of the grommet in the boot then kind of twist it in there. I thought it was simple, if you have trouble just use some kid of lube. It's an important part beacuse the neck of the shifter is less diameter than he hole cut in the inner boot.
junior04
09-28-2015 10:53 AM
