threw a code tonight
RE: threw a code tonight
Unfortunately,,I'm not at work today(shopkey snap on schmatics to review the codes),but given the codes 138 and 158 (both rear 0s codes),,,do you have the mil eliminators?Also could not find the other code p2273...not sure ,,,but still,,,,REAR o2's monitor cat efficiency only,,,,will not effect the car (unless they completely short(12 volt heater circuit)....and are just for emissions.....If It where mine....I'd drive on....
Also fuel- air metering codes are usually po100 to po296 .....
wow thanks for the knowledge. do u think the water could have shorted the MILS out? becase i disconnected the battery after everything dried up and drove for about 20 miles and no CE light now.
well after all day of everything working fine, i went out at about 11 PM to dop off a friend, and the light came back on. im going to point the finger to a shortage again because of the rain. it was a little wet out. so i disconnected the battery last night and left it like that all night. ill reconnect everything in a little while.
lincolnshibuya
12-08-2015 04:37 PM
BeatnikFink
10-01-2015 08:00 PM
