is this true?
Old 11-22-2006, 04:06 PM
MoKo_04GT
MoKo_04GT's Avatar
Default is this true?
the fallowing is a word for word quote taken from brenspeed.com under the pypes x pipe information : "x pipes create more power and torque than a h-pipe b.ecause they merge your exhause pulses at the "x" . traditional h-pipes loose this ability above 3,000 rpm's, and the h becomes non-functional."
is that true?? more power AND torque?? h becomes non functional after 3k rpm's??
MoKo_04GT is offline
Old 11-22-2006, 04:22 PM
PushinTheLimit
PushinTheLimit's Avatar
Default RE: is this true?
[sm=bs.gif] The comparison of power and torque is minimal... whoever told you that, needs to go flush their head in a toilet because they are full of ****.
PushinTheLimit is offline
Old 11-22-2006, 05:55 PM
sandcracker21
sandcracker21's Avatar
its true and false
its true that the x-pipe will give you more hp (i dont know about tq)
its false bc the x-pipe might give you 1.2 more hp at best
as for an h-pipe being "useless" after 3k rpm, thats just bs
sandcracker21 is offline
Old 11-22-2006, 06:01 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
You'll see more peak HP with the x-pipe.
You'll see more hp/tq down low with an H-pipe.
Either way, whichever mid-pipe you choose isn't going to keep you from winning or losing a close race.
I'm pretty sure Brenspeed.com is just using the manufacturers description & not his own for many of his products. If you are looking for more concrete answers, call Brent. He has an in-house dyno and is very experienced.
Dan04COBRA is offline
Old 11-22-2006, 06:03 PM
rvoss5
rvoss5's Avatar
ORIGINAL: sandcracker21
its true and false
actually it's not after a certain speed. it's at wot. the exhaust gases are passing through the exhaust system faster than it can cross the connecting pipe. an x pipe is proven to be better for the 1/4. it's just really not enough to justify using it is all imo unless you just want one. i will be using an x pipe when i upgrade my exhaust though.
rvoss5 is offline
Old 11-22-2006, 06:09 PM
xxkazp3rxx
xxkazp3rxx's Avatar
There isn't much of a difference in power between the two. Like Dan said, xpipe will give you more hp up top, but the h pipe will give you more power down low... depends on what you're looking for. Also hpipe has a deep sound, where as xpipe has a raspy sound almost like nascar.
They say xpipe sounds better with non chambered mufflers, and hpipe is better with chambered mufflers.
xxkazp3rxx is offline
Granatelli Sales
01-20-2020 12:34 AM
winner99
09-30-2015 07:04 PM
treesloth
09-28-2015 07:03 AM
2015Ecoboost
09-17-2015 01:48 PM
TfcCDR
09-12-2015 04:13 PM
Quick Reply: is this true?
