steeda tri ax
steeda tri ax
i just did my steeda tri ax installation today and i have to tell u that it rocks the shifter is awesome great shifter i am very happy with it ,the only thing is that sometimes i miss 2 gear it went to 4th but i love it . The install was easy the hardest part was to remove the stock shifter i have some questions tho the when i set the shift stops i did it using 3rd and 4th gear is this ok also which position u think is the most comfortable the lower or high to set the shifter handle .
RE: steeda tri ax
TR 3650's have internal shift stops. I wouldn't use them if I were you.
I prefer the lowest height setting. It also gives you a shorter throw.
Tremec Transmissions
Service Bulletin 03.01
Subject:
Aftermarket Shifter Stops
Transmission Models Affected:
All
Severe damage may be caused by installing an aftermarket shifter with "shift stops" on any TREMEC transmission. All TREMEC transmissions are designed and manufactured with built-in shift stops to prevent over shifting. Therefore; shift stops on aftermarket shifters are totally unnecessary when used on a TREMEC transmission. TREMEC "TR series" transmissions have multiple shift rails with shift stops on the gearing. TREMEC "T series" transmissions have a single shift rail system with stops built into the guide plate.
When installing an aftermarket shifter on a TREMEC transmission it is best to remove the shift stops to avoid miss adjustment, and the potential of the screws vibrating lose. A misadjusted shift stop can cause an under-shift, which may lead to a gear jump-out situation. If the transmission jumps out of gear, the shift fork can be bent causing permanent damage to the transmission. Shift forks can also be damaged by "clash shifting". A clash is caused by a missed shift.
Neither an "under-shift", nor a "clash shift" can be prevented by shift stops. TREMEC shift forks are designed to take loads up to 1,000 lbs. However, a gear jump-out may well exceed 1,000 lbs. of force, which may result in a permanently damaged transmission.
Subject:
All
RE: steeda tri ax
hmm i didnt know that the 3650 had internals stops... good to know
but I agree I love my triax... I want to try an mgw - but i cant see how its worth the xtra dough - i bought my tri ax used for 90.00 shipped
RE: steeda tri ax
thanks so u did not set the shift stops i only did it on 3rd and 4th gear and there is a small gap between so i think i am ok because when i shift the gear does not pop out that means is ok, it feel stiff and hard when shifting but i assume is because of the new shifter am i correct.
09-10-2015 08:39 PM
09-08-2015 11:50 AM
09-02-2015 08:40 PM
09-01-2015 08:16 PM
