Convertible top & parking brake relay modification...
I have an 03 GT convertible. I would like to be able to put the top up and down with the parking brake down (off) -- for example, when I am in traffic or pulling out of my garage / driveway.
Any suggestions as to where the parking brake relay for the convertible top is and how it can be jumped-out to operate with the brake off?
Any help would be appreciated.
Thanks,
Rich.
Thanks,
Rich.
RE: Convertible top & parking brake relay modification...
There's an easy way around this...in case you haven't noticed, the emergency brake doesn't have to be fully engaged to allow you to put the top up or down, just pulled enough for the light to come on in the dash. So, if you pull it up only 1 notch or so, just enough to trip the relay, but not engage the actual brakes, you can put the top up and down while rolling. I wouldn't recommend doing this at speeds over 20 or so, though, I think that's about the fastest I've ever done it.
Honestly .. it only takes 20 seconds to put the top up or down .. if you can't stand to sit there in traffic for that long then you just need to get over it .. you bought a convertible it comes with the territory .. but seriously man ... its not that hard to just pull over !!!
From one vert owner to another
FYI. it wont let you put it down so you don't ruin your Top frame. If you put your top down while you are moving you create a sail and your top is catching all the wind from you moving and could bend the frame of the top all out of whack. I can't believe the guy up there told you it was OK to put it down going 20 MPH.
20 seconds?! how old is your stang? try around 6 sec.
ORIGINAL: akelemecz
Yeah dumb f u c k .. I'm talking about the time it takes to pull over .. yank the e brake .. unlock the tabs put it back and dis-engage the e-break and go ..
I really have to say .. you win the ignorant **** for brains trophey of the month !!!!
Point B .. I'm not the dumbass trying to put my top up and down while driving .. so suck on em for a second will you punk !?
Well then, I guess experience isn't enough justification....in case you didn't notice, I DO own a 'vert, and I've done it at speeds up to 20 or so. I figured the frame had to be created with winds up to a certain strength while putting it up or down in mind, so it should've been designed with these kinds of tolerances in mind. Forgive me for thinking it through a little bit, though.
ORIGINAL: BraMas
all i do is pop the latch and press the button. i dont even bother with putting it back...its real quick. its really no point to do it while coming out your driveway...just eat a fruit snack or something while its going down. Mine takes like 10 seconds max.
