Oil Change Suggestions
RE: Oil Change Suggestions
mobil 1
well if you havent been runnign synthetic up to this point then I would not put it in - I have been told that pasy 30-50k miles synthetic will make your car start weeping oil and be a real mess- if its dry under your car right now then, I would say try it - but if its already wet - then don't switch it
Do you mean leaking oil? If so it is not but I have had the car for 5 weeks, 3,200 miles. I have already added 1.5 quarts...so I assume it is burning? There is no puddle in the driveway? Weeping do you mean leaking from the undercarriage? Thanks again and Happpy Gobble Gobble!
