Shiftlight
#23
RE: Shiftlight
ORIGINAL: eventer289
Where do you run the wire through if you mount it in the guage cluster?
Edit: I'm a doofass, I read that as if you meant a pod cluster on the pillar. I would still say you could run it underneath the cluster trim in the dash. Maybe drill you a small hole to actually get it through the dash to the underside.
#24
RE: Shiftlight
#25
RE: Shiftlight
ORIGINAL: stang2000
I didn't drill any holes to run the wire. The back of the trim bezel pulls out enough to slide the wire behind the bezel and around the side of the cluster, then of course like he said above, run it down along the underside of dash, wiretie as needed and feed to the ecu in the passengers kick panel.
#26
RE: Shiftlight
It's not that bad. I actually don't remember how long it took me. Maybe 30-45 minutes . Probably just because deciding where to mount it. The hook up is really easy and the instructions are very clear. The light shows power whenever I start the car yes.
varam03
06-09-2008 02:08 PM
