weld wheels
weld wheels
what size wheels could i run up front if i daily drive the car often? i been lookin into 15x4' for the front and 15x8' for the rear...but what do u all think since i drive the car daily every now and then!
RE: weld wheels
If i was running it ever now and again I would go with a 15x3.5 up front and not look back. Now it was a DD I would be looking at a 15x6 or a 15x5, but would still really be thinking about just getting the 15x3.5 up front. If you never go to the drag strip, get a wider wheel, if you go to the track alot, get the skinnier wheel. All a matter of preference.
for the back 275/50/15's look better on a 15x9 with a 6" BS.
still have to have the same spacer up front no matter the size. That or you can grind on the caliper. No grinding you will need a 7/16". Less than that you will need some grinding done. Think the smallest size in hub-centric spacers are 1/2"
Don't over look the wheel studs though.
RE: weld wheels
on my dd i use 15x6 front 15x10 rear
front used 7/16 spacer and still had to grind very little.
these are the only pics i have rite now, there not really a good angle
[IMG]local://upfiles/22011/1E0EA3C21E6347609436291E4536A0AB.jpg[/IMG]
[IMG]local://upfiles/22011/8CC6C317DFC34953A4AE0764EBD182B1.jpg[/IMG]
RE: weld wheels
ORIGINAL: rmedcoFYI -- Not sure if this will effect your decision or not, but Weld Wheels is in bankruptcy (in case there are ever warranty issues).
jwog666
12-27-2021 08:09 PM
mungodrums
09-28-2015 10:54 PM
