cams
cams
ok im thinkin of cams what r good for my 02 auto gt
i just looked at what my fiance is getting me for x mas mid pipe from bassani and catback from i dont no. what r some good cams running n where can i find more info like performance wise.
would geting cams be noticeable
RE: cams
depends on your budget and what you expect of them. Just more power and a more limited budget? i have vt stage 1. They added about 30rw (guessing, i put them in and my headers on at the same time and picked up 45rw) and they have some lope to them, you can definitely tell it is cammed and it was really noticable power-wise.
If you want the big lope then go more aggressive stage 2 or eqaul. but more money cause of springs. If you do that, try to find someone to change them without pulling the heads, save yourself alot of dough. Downside to stage 2 or above? max power curve out of where you can use it (7K rpm +).
try vtengines.com. crower makes good cams as well. look in people's siggys to see what people are running.
RE: cams
ORIGINAL: sleeping stallion
ive seen those vt ones wuz up with those and stage wise i dont no what that mean any help would thanked
Stage 2s are more aggressive, bigger lope, need springs, more cost. alot of people wont do them with a stock bottom end. Imo, you should have gears to get over the lack of low end. I have 410s in mine that helped. power wise, not sure how they compare to a stage 1 on a stock rev range.
Stage 3, higher still, need some serious mods to get the benefit.
I am talking n/a here as well, they also have blower and turbo and custom grinds available as well. Call Scott and talk to him. he will guide you.
I think the crower goes like, 270 for mild,then 272 and such for their agressiveness.
RE: cams
i see so lets say i go with stage one cuz im nowhere to being modded for stge 3. would it be worth it any price u no.
if i get these cams and later on in the future get different heads will they fit on there or have to get all new ones
junior04
09-28-2015 10:53 AM
