Wet or Dry Nitrous Systems?
RE: Wet or Dry Nitrous Systems?
Nos is just a bad idea but dry is easier all u do is stick the nos line in ur intake and bam dry shot for the wet u tap off one of ur fuel rails and their is ur wet shot thats basically it nos is hella ez to do
ORIGINAL: 04charcoalgt
im srry nitrous is horrible for a motor not ment to run on it idiot
ORIGINAL: geetee03
people who don't know much about nitrous will typically say something like this. not worth arguing[sm=shutup.gif]
I've run nitrous on every stang I've ever owned untuned. Use a window switch with a 3000 rpm chip on the activation side and spray up to a 125 shot without worry. If you try to spray 125 at low rpm without retarding your timing you may end up like this guy I know at the tree with your car on fire from a backfire. I ran a 125 shot for three years without tuning and never had a backfire.
I can't understand anything you are trying to say charcoalgt, but being a ween like you are won't get you very much help here.
Anyways, running un-tuned on nitrous is an ugly idea, there is steps you can take to make it safer, but it's still best to have a tune.
Wet systems will be safer, but you'll be best off using a window switch, so you won't be too low in your powerband spraying and cause an ugly nitrous backfire.
bradleyb
11-27-2015 07:50 PM
breaking
10-02-2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
