3.73 gears
RE: 3.73 gears
Everyone will say something different basically you want to take it easy in the beginning make sure everything sounds right etc so Gear break-in procedure should be as follows for a streetcar. Drive at normal street speeds for 10 miles; let it cool for 30 minutes. Do this 3 times and then let the car sit. Check for whining or vibrations while doing this, there should be none if you followed the shimming procedure and setup the backlash within spec.
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
