Brighter Lights
Brighter Lights
As of now my headlights completely suck. They reach about 20 feet in front of my Mustang but have a very dim and yellow light. I would like some lights with much further range and a bright, whiteish light. I am thinking of going 4300k HID lights from stangmods.com. Is this my best choice? I do not have money for headlamps too (unless the bulbs are very cheap).
RE: Brighter Lights
Silverstar Ultra's give off a very nice white light.
My neighbour just put a set in his truck and it's like night and day.
Cheap to buy too versus true HID setup.
Not sure about longevity though. I have heard regular Silvertars burn out faster than regular bulbs.
RE: Brighter Lights
HIDs will be much brighter and reach farther. If you want really good vision go with the HIDs. Also how clean are your headlights--inside and outside? Try wetsanding the outside and cleaning the inside and see if that helps out a little.
EDIT: One other thing, Im pretty sure if you go with HIDs you will no longer have a dim/bright function. It will be the same light at all times.
RE: Brighter Lights
you can use reg headlamps but you should aim them down a bit as the reg headlamps scatter the hid beams a bit, if your looking for hid's and a new headlamp go talk to matt at stangmods. i have his 6000k bixenon and foglight hid kit on smoked clear corners, might be buying projectors later on but not certain
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
