loud rearend noise......kinda scary
Old 12-03-2006, 05:17 AM
travisl1213
travisl1213's Avatar
Default loud rearend noise......kinda scary
just started a few mins ago, on take off slight rough shaking coming from the rear, when i go to make a turn then its a loud rubbing noise kinda like a grind. i know its from the back but thats all i can tell. nothing looks bad or loose. any ideas?
travisl1213 is offline
Old 12-03-2006, 10:21 AM
Mark99GT
Mark99GT's Avatar
Default RE: loud rearend noise......kinda scary
Does it make the noise at higher speeds around corners under acceleration? Can you still leave posi strips? I had the same symptoms you describe, grinding and such. My diff is on its way out. Had metal pieces in the diff fluid. A simple fluid change made the noise go away completely though. I'd definitely try changing the fluid. While you're at it, get a diff cover with a fill and drain plug, makes the job easier in the future.
Mark99GT is offline
Old 12-03-2006, 11:13 AM
stang2000
stang2000's Avatar
I"ve got a new eaton 31 spline diff and new moser 31 spline axles for sale if you need!
stang2000 is offline
Old 12-03-2006, 11:49 AM
fishyducky
fishyducky's Avatar
+1 mine makes some noise too, i replaced the fluid and it went away and i had a small amout of metal shavings in the rear end. im replacing everything back there this christmas tho so im still running the heck out of it.
fishyducky is offline
Old 12-03-2006, 01:17 PM
96cobra10101
96cobra10101's Avatar
make sure your fluid didn't leak out.
96cobra10101 is offline
Old 12-03-2006, 02:33 PM
travisl1213
well i hit a whole in the road last night and its just a loud noise that sounds like something is going to break. i had my rearend rebuilt about 10000 miles ago.
Old 12-03-2006, 05:02 PM
travisl1213
drove it to work today about 8 miles and it drove great and no noise at all..... weird.. any ideas of something to check
Old 12-03-2006, 10:50 PM
travisl1213
bump
FivePointToTheOh
03-09-2020 10:26 PM
KingRando
10-02-2015 08:06 AM
MustangV6P
09-28-2015 11:00 PM
67LimeCoupe
09-21-2015 06:34 PM
Quick Reply: loud rearend noise......kinda scary
