Does CEL turn off after fix? - MustangForums.com
Old 12-03-2006, 09:13 PM
jmac72187
corner carver
jmac72187's Avatar
Default Does CEL turn off after fix?
After fixing something that set the check engine light off, does the CEL turn off or do you have to turn it off with one of the computer things?
jmac72187 is offline
Old 12-03-2006, 09:16 PM
sitnlopro99gt
Default RE: Does CEL turn off after fix?
you can undo battery terminals for a few 1 min or 2 and then put it back in it will reset that way and yes it should go off after you do that and it will stay off if fixed you could also do it through tuner
sitnlopro99gt is offline
Old 12-03-2006, 09:17 PM
jmac72187
corner carver
jmac72187's Avatar
I replaced the camshaft positioning sensor like it said and let it run for about 30 seconds. It didn't turn off. What should I do?
Old 12-03-2006, 09:22 PM
sitnlopro99gt
disconnect battery for a few mins and then hook it back up try that
Old 12-03-2006, 09:24 PM
jmac72187
corner carver
jmac72187's Avatar
will do
II 98 GT II
If that doesn't work take it to autozone
II 98 GT II is offline
Old 12-03-2006, 09:26 PM
kylebgt
Yes I believe that after the CEL is tripped it will still stay on even if the problem is fixed. Just reset the ECU by unhooking the battery for a few minutes.
kylebgt is offline
Old 12-03-2006, 10:04 PM
jmac72187
corner carver
jmac72187's Avatar
Alright thanks guys. It is off. Now hopefull it is all fixed.
Off Topic
22
09-11-2015 09:00 PM
Pyrate Dave
09-10-2015 08:30 PM
Jose Corretjer
09-08-2015 07:32 AM
Quick Reply: Does CEL turn off after fix?
Featured Sponsors
