stay NITTO or go BFG- ?
RE: stay NITTO or go BFG- ?
im not talking about those BFGs picture above. im talking about the GFORCES.
http://www.tirerack.com/tires/tires....FA+Drag+Radial
other than these are the 555Rs the best others i could go with? or would some michelins or toyos be better?
toyos are a really good tire go with the toyo proxy t1-r they havent been out to long I run them on the front they are a get wet and dry performing tire and have great traction and have a better wear rating than any of the drags and there fair priced
ORIGINAL: Zero 16X
i have bfg gforces on my rear. before i had Nitto 555s. They were cheap peices of rubber compared to these. I have had about 6k on them and theyre still running with more than half tread... i expect at least 10k-17k more out of them.
My car came with a set of bfg geforce on it (bought it used) and it was a tire smoking car. Hard powerslides in 2nd gear every time, espcially with the 3.73s.
With just flows/k&N and the 3.73s my nittos almost completely shut down the 2nd gear scratch. Just simply no comparasion.
I have never had the regular 555rs on the back (non drag radial nitto) but they seem to do really well on the front.
no.. im trying to compare what i should get both BFG and NITTOs RADIAL wise.
i am currently running the nitto RADIALS in the rear and the NON-RADIALs up front, i like the setup.. but what im asking is- is there anywhere better to go..?
if not ill stick with them. i have just heard like multiple GOOD GOOD comments on the BFG gFORCE radials. i just wanted some feedback. only downside i heard was they last very SHORTLY vs the nitto radials.
ORIGINAL: dvs_03gt
Unfortunatley im running saleen 18x9s so i cant go bigger.
anyways WHICH TIRE SHOULD I GO WITH???
i have nitto 555's (255x35's) on the front
and nitto 555radials on the rear.. 285x35
i have like 12-15k mi on the nittos. so i def. need to ones in the rear?
should i stay or go? only the rears..
The Nitto's are going to wear a little better on a DD verses the same size BFG.
The BFG's is going to give you a little better traction versus the same size Nitto.
thanks for the perfect explanation. i already understand all that. i just was not sure which ones i should keep. you see i swap them out with a much cheaper non radial tire for my avid driving/crusing (its not a dd more so a 3day a week driver). other than that when i have fun and go out on fridays or track nights i swap the 555Rs on. (no need for slicks)
ORIGINAL: dvs_03gt
So,,,,,,,,what you want "us" to do is to make up "your" mind on which rears to keep?
lol more so, is there something better out there? that i should look into? i mean i usually run normal 555s on the rear when on the go. so its mostly- i need a new set of serious tires. ive even seen some michelins but they get $$$
