Magnapack catback?
RE: Magnapack catback?
ORIGINAL: stangc83
well de to the bolt on exhaust, the heat and the cold change will make the exhause shift. it took awhile to get the exhaust exactky where i wanted
well did your shop weld or didi it just bolt on. I had a prob with the axle overhang hitting the trrnk. then the rear kept coming loose due to the fact that i didnt use the lock stuff. you can't hear it unless you know your car. but i know my car to the T, so any rattle, any twitch i know. I have done everything myself on my car. not many people can clain that.
ORIGINAL: stangc83
Loosen the bolt on the rear of the tip a little. You should be able to maneuver it then. If you still can't get it into position, loosen the alan screw on the tip hanger to let the rod rotate freely and then adjust. Once you have it in position, reverse the process.
The only issue I've had is that the left tip does not tighten enough on the tail pipe and vibration cause it to move back under the car. Not enough to come loose from the hanger, but the tip just recesses below the bumper. I fixed it by putting a 2.5" hose clamp behind the tip on the tail pipe. Now, the tip butts up to it and cannot recess. Cost: about $2.
Wow, we have purty cars. Gotta love Sonic Blue.
ORIGINAL: 04BlueGT
panic
09-10-2015 05:56 PM
mryeah256
08-28-2015 02:01 PM
