Gas pedal problems...
RE: Gas pedal problems...
Yeah... It has BBK springs on it. First I have to pull the car up on 1 inch boards to get the jack to go under it, then I just jack it up, put jack stands under the A arms, and drain them ****s!
ORIGINAL: kylebgt
Just out of curiosity did you drop the stang 1-2 inches? Maybe the picture just hides the 4x4 look of our cars. If you do have it dropped how do you change the oil? I want to drop mine around 1.5' but still want to be able to easily change the oil in my driveway.
Ha...good luck. Mines lowered between 1.75 and 2 inches and I cant even get a jack the front. I have to back it into the garage so that the front tires are just barely on the garage floor. Then, using the decline in the driveway, slide the jack under the front end, jack it up a few inches, put 2X4s under the fronts, lower it onto the boards, then jack it up the rest of the way from each side. Only did that twice, and its a pain in the ***. Ramps dont work either.
Matt
ORIGINAL: kylebgt
No prob, If it this doesnt work then your gas pedal will be rendered useless. Meaning that you cant drive your car, which would mean you have to give those rims to me
I'll arm wrestle the midget in the green for the rims.
If all else fails, make a trip to the local Ford dealer and buy some new parts.
