Racing pedals from AMerican muscle
hey guys i just got racing pedals from american muscle have ne one installed these before if so can u explain how to do them n how easy it was thanks
justin |
RE: Racing pedals from AMerican muscle
ummm, you take the face, put it up against the rubber, take the back clips, and screw them in, done.
if your referring to the ford racing pedals, heat the clutch and brake pedal up in boiling water for like 2 mins and then be careful not to burn your self and just slip them on once you have the old stuff off and let them cool. With the gas pedal I found it easiest to undo the whole pedal assembly from the firewall so I could twist it to see the behind it. There are two bolts you have to take off in order to do this. Once that it is doen have full access to everything. Just whack the pin out with hammer.
