need help asap new engine noise
it is a forged 99 gt with stock heads aftermarket cams and vortec t-trim. we just started the car for the first time and the car started fine but we hear a loud noise in the front passenger side it is a very loud ticking noise. it is definetly the top end of the motor. i have two questions, one is it a lifter issue, and two can you change the lifters without pulling the heads off. also how do you check to see if the lifter is the problem. please help because my car has been down to long and i need it fixed quick
RE: need help asap new engine noise
If you changed the spark plugs something could have fell in. Pull the plugs, and see which plugs is messed up. Then pull the head, and clean it out. DO NOT LET IT RUN LONG!
It may or may not be this.
ORIGINAL: 99roushgt
its not a rod knock its ba 100% brand new engine everything is brand new just fired it for the first time and heard this i doubt anything fell in there it spun freely but i will pull the plugs and see if any are damaged its definately in the top end and sound like its #1 cylinder i just dont know what a stuck lifter sounds like or if that is even the problem
ORIGINAL: 99roushgt
Pull the valve cover off and do a visual.
its a 550 lift cam stock components except for valve springs and the noise is only on the left bank (passenger side) driver side is awesome no noise sounds like its stock so i dont know about PTV contact
It isn't a lifter for sure, unless you have swapped a pushrod engine into the car :
https://mustangforums.com/m_1525549/tm.htm
ORIGINAL: 2000GT4.6
O.K.,,,Hydraulic Fulcrum. Terminology has changed with the ohc, but it does the job a lifter used to do in an in-block cam motor.
