BBK LT's OR MAC LT's?
This one is basically comming down to everybodys knowledge and/or experience with either brand. Which one does everybody prefer? I want them to last, not something im going to invest in and have to replace 4 or 5 years later. Also, ive heard about clearance issues with LT's being lower to the ground as well as a difficult installation, can somebody give me the facts that i need to know like if its a small or large clearance difference and the main idea with the install, ive been told the engine needs to be pulled? is this true?
Thanks...
Thanks...
RE: BBK LT's OR MAC LT's?
I have BBK Lt's and I didn't have any issues. I put mine on when the motor was pulled, dropped K-member, trans, etc. Even with the engine on a stand while still attached to the K-member its was a little tricky. It still took atleast an hour per header. The passenger side one was harder to squeeze between the head and the k-member and then trying to access the bolts and get the gaskets lined up was the biggest b*tch. I have heard of people leaving the motor in while doing it although it has also taken them half a day to do it. It you have access to a lift and can pull the motor, do it. If not just have patience and a few beers and you will be good to go.
ive always heard better things about BBK Ceramic Coated Longtube Headers.
they do go lower than stock exhaust...but clearance issues shouldnt be that bad except for over speedbumps and stuff i think. im pretty sure there a re people running LT Headers who are also lowered 2" and have a a body kit.
Install sucks...im having my speed shop do it. They hafta drop the K member and stuff...theyre charging me $400.
if you do end up gettin em...might as well get a good set of header gaskets that will last so you dont hafta go back in there later.
If your car is lowered at all you may bottom out the lt's on speed bumps and stuff, I do, you just have to be carefull. By the way, I have that stuff for sale if your interested pm me.
You are going to run into problems with the MAC LTs during installation... Fabrication is going to be needed. This is why I went with the BBK LT's, perfect fit, zero issues, great product.
my suggestion... if your gonna buy MAC LTs dont buy em used... they tend to warp and then you have your self one PITA install... even though installing LTs is a PITA anyway but with warped headers it will be even more or a PITA.
