Mods leading up to the supercharger..........
This spring i plan on getting a procharger for my 2002 Mustang GT Auto... so far my mods are 4.10 gears, Accufab 75mmTB/plenum, SLP X pipe, Borla Stinger catback, diablosport predator tuner and im having a stall converter installed in late march/early april...What else will i need to get about 420RWHP? Im assuming i will probably need LT headers.... ALso, are Partiot heads and cams worth it or should i just skip these?
RE: Mods leading up to the supercharger..........
ive never heard any complaints with the heads. i would go with comp stage 2 cams with patriot heads to match. along with headers and bigger injectors, and one good tune but then again what procharger are you getting???
most likely the P-1SC.......btw whats the difference between the P=1SC and the D-1SC? I was going to get a Kenne Bell or Saleen series IV but with my 4.10 gears i would probably never get traction, plus i have the TB/Plenum that i can use with a centrifugal..
i would think that:
HEADERS (LT)
CAMS(STAGE 2 0R 3)
HEADS
RIGHTEOUS TUNE
BIGGER INJECTORS
i think that would definitely do it. id rather go with KB. there new blowers are so much more efficient, and the boost lasts a bit longer now. they also make more power. that 2.1 kit is mine.
by that way that is a beautiful mach
HEADERS (LT)
CAMS(STAGE 2 0R 3)
HEADS
RIGHTEOUS TUNE
BIGGER INJECTORS
ORIGINAL: nanaki
the diablo will have to go
ORIGINAL: JJ03MustangGT
hell be fine with 410s if he goes with a centri....a twin screw makes too much boost down low and youd spin your tires bald in a launch
