vt stage 1 cams or 4.10 gears first.
vt stage 1 cams or 4.10 gears first. I want my car to feel like it has more tq. Which would I feel the most? I will eventually do both but this is going to be my xmas present to myself from my wife.
RE: vt stage 1 cams or 4.10 gears first.
flip a coin. if it were me i would do cams because ull get a little bit of performance with a decent idle...but then again i did gears first on my car and no regrets so far. either or is a good choice
but did you forget about refilling the bottle and always having to hit that dern switch. not mention that once a blowers on its on. the boost is always there. it doesnt keep askin for money so that it can make boost.
ORIGINAL: nanaki
because you can get just a big of a gain from a 100-125 nitrous shot for $499 as you would for a 10psi supercharger at $2999
get a quote from superchargersonline.com for a vortech kit. it's not hard to find a vortech for 3 grand.
did you forget it doesn't cost much of anything to refill? the juice also lasts quite awhile. and what switch? ok, you hit 1 switch to arm it, wow, huge deal. otherwise it acts just as a centrifugal supercharger would. starts automatically spraying at about 3k rpm, just as a centri starts to build boost at 3k, but isn't at max boost until almost redline though. so the juice gives you even more power faster.
