1998 GT hard starting
I have a 1998 GT and it only has 39000 miles on it. Although it started the problem at 38,000 miles. Basically in the mornings particularly, it takes a while to start while im cranking on the starter. It seems that the battery isnt bad though because it does its job. The battery will always cranked the motor over untill it starts. I thought for a while it was because the engine was cold but it sometimes does it during the day. What do you guys think the problem could be. I thought I noticed a few times that it starts easier with a full tank of gas in it. But sometimes it will do it then too.
I also considered the problem to be the fuel filter and debris was not allowing enough gasoline flow but I had my fuel filter replaced 300 miles ago...
Thanks,
Mike
Thanks,
Mike
RE: 1998 GT hard starting
Not hard at all. Not a fun job though.
Get under rear of the car. You'll find it tucked up near the back of the gas tank.
before you start, find the fuel cut-off in the trunk. Press it. Start the car and it should stall in a few seconds.
This removes pressure from the fuel lines.
You'll need wrench or socket and some pliers and some ramps.
You should change it every 30K or so.... If you have a used car and have never changed it, its always a good idea.
Well thatnks for the replies guys. Ill check the spark plugs! If its not that then ill move on to the fuel filter. Although I just had it replace so ill check that last ...
