C/A harder then i thought SPRING ISOLATOR Q
C/A came today well i wanted to start.... and man with hand tools and jack stands it's alot harder then i thought. had to take my exhaust off.... was not expecting that
my question is my rear sits a little higher if i were to take off spring isolators will my ride be worse? will it cause the grinding sound?
is it safe?
if so should I take both or just the bottom or just the top?
Thanks
is it safe?
Thanks
RE: C/A harder then i thought SPRING ISOLATOR Q
Taking off the spring isolators will drop the car another 1/4 to 1/2 inch.The only thing is now you will have metal on metal,and it may cause a squeaking noise.But alot of people on here have no isolators and say they have no noise.
ORIGINAL: mustang281
that's what i thought..
thanks
ORIGINAL: code3GT
I removed my isolators. I wrapped the bottom coil with electrical tape.
I thought about that but figured it would wear out eventually
but i havent finished will do it tommorrow... and take em off
Thanks you two
mungodrums
09-28-2015 10:54 PM
09-25-2015 09:06 AM
mungodrums
Suspension
09-24-2015 10:12 PM
