NPI 4.6 Air/exhaustflow
Because im on a budget and I am in High School Im looking into doing a cam and intake swap. But ive thought about it and lets say that I get a PI intake,TB,plenum and MAF would all that not really do much with stock cams. Would I need to upgrade the cams to see any HP.
If i upgraded the cams should i put PI cams in or VT stage 1 cams?
PS:Im already aware that this motor doesnt respond well to mods
Mike
Mike
RE: NPI 4.6 Air/exhaustflow
Cams are not worth the money on a stock engine. They are really only beneficial if you plan on FI or running some juice. I would say either go the PI route or keep it how it is and get an intake, tb, chip and call it a day.
PI cams would improve hp and trq but is not worth the effort and money. If you really want to see gains you should get a whole PI head <the cams really work best with the PI valves etc. Or you could save a little money and just get a 99' new edge
Some people shouldn't reply if they have no clue [:@]
Doing the PI intake swap is great but adding the pi cams is even better...it will help you make more power higher in the rpm range. Together you will see a solid 30rwhp gain for a minimal investment. Its one of the best bang for the buck mods a NPI can do.
+1... I'm on Mustang Forums, too and I read that whole big write up about doing the whole swap compared to doing the intake/cam swap. After reading it, I realized that I just wanna do the cam/intake swap. Spending so much more money on just the heads that will only add about 10 more WHP doesn't seem worth it to me.
10-09-2015 03:27 PM
