How often do you beat on ur cars??
Old 12-11-2006, 02:38 AM
  #21
Crazyfast50stang
Crazyfast50stang's Avatar
Default RE: How often do you beat on ur cars??
Everytime I get into it.... I know I know bad habit.
Crazyfast50stang is offline
Old 12-11-2006, 02:54 AM
  #22
lizzyfan
Underboss
lizzyfan's Avatar
Once a week to terrorize the ricers[sm=gears.gif]
lizzyfan is offline
Old 12-11-2006, 03:00 AM
  #23
Colorado_Mustang
Colorado_Mustang's Avatar
Probably every time I drive it with rare exception. A minimum of once per tank...usually 3 times or so. Mine pulls strong past the factory redline...right into the limiter. Don't know why you low-landers are having problems above 5100.[&:]
Colorado_Mustang is offline
Old 12-12-2006, 12:05 AM
  #24
7arpad7
7arpad7's Avatar
ORIGINAL: tehzack
6800!?! Why? Your not making power at that RPM on a motor w/o some serious cams.
It's a 1997 4 valver... redline is at 6800 with the fuel shut off at 7000. Max power is at about 5800, but still hangs in there strong up to redline... and by getting the revs up that high I can get into the next gear at a higher RPM and consequentially higher HP... I could most likely get the same performance if I were to shift at 6500, but it spins that tach dang fast!
Drive it like you hate it... as someone once said...
7arpad7 is offline
djbigskrilla
09-20-2022 01:04 AM
09-08-2015 04:35 PM
Urambo Tauro
09-07-2015 12:47 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: How often do you beat on ur cars??
