used s/c price ??
I posted this in pipes , boost & juice also , but thought I might get more responses here .
one of my buddies wants me to buy his s/c . he got it used about 4 yrs ago & never installed it . it's a vortech , not sure what model . it came off of a 98gt & if I got it I would put it on a '01gt . he doesn't have all the parts . he just has the head unit , tubing , filter , bpv & some other small stuff(forget). it's pullied for 8psi . I have larger injectors , pump & gauges . I've known him for over 15 yrs so he will basically take whatever I offer him but I want it to be a fair deal & I have no idea what it would be worth & neither does he . so , my 3 questions are : 1. do they sell just the engine to s/c adapter plate by itself ? 2. what would you pay for the s/c & other parts he has ?? basically just the s/c 3. should I just pass on it ? I tried to check vortechs site about the plate but its under construction . thanks for any advice . |
RE: used s/c price ??
well they do sell just the s/c brackets and dependant upon what he paid for it and if it was used when he bought it i would make my decision on price and model would make a big difference in the price, the only reason for you to buy it would be to turn around and make money off of it seeing as you already have a kb blower (atleast your sig says so)
I have a 2001gt also that I would put it on . the s/c is used about 10,000 miles .
what did he pay for the kit?
We would probably need a complete list of what the parts are, along with the blower model, to give you an accurate price. |
ORIGINAL: 2000GT4.6 what did he pay for the kit? We would probably need a complete list of what the parts are, along with the blower model, to give you an accurate price. did they make the V2 s-trim 4-5 yrs ago ?? |
1000 bux
I bought mine used. It came from a 96-98 kit and had supposeldly 10K on it. Found out that the actual head unit was 5 years old and it had new seals and bearings put in a year ago. The kit I bought came with the head unit, discharge pipe, intake pipe, a few sleeves, 96-98 bracket, and a bosch bypass valve. I paid $750 for that setup. Then I found this great website called Superchargers Online and they had every single other piece that I needed to complete the kit. I bought from them: 03 style bracket, oil feed and return lines with the nozzle, MAF adapter plate, bracket/alternator spacer, aluminum ribbed idler pulley, and plastic smooth idler with the little flanges on the sides. Then I went to the hardware store and found all of the bolts I needed. Then I bought a new lightning MAF, 03/04 cobra injectors/pigtails, screw-in IAT sensor, and a Diablosport chip. Total cost was around $1500 before tuning for my used kit.
Here is the link to the vortech manual. It has all the parts lists with everything.Vortech Manual Hope that helps.:D Definately buy it from him. Its alot of work/money but its worth it in the end. |
ORIGINAL: rvoss5 1000 bux |
ORIGINAL: Frostbitten I bought mine used. It came from a 96-98 kit and had supposeldly 10K on it. Found out that the actual head unit was 5 years old and it had new seals and bearings put in a year ago. The kit I bought came with the head unit, discharge pipe, intake pipe, a few sleeves, 96-98 bracket, and a bosch bypass valve. I paid $750 for that setup. Then I found this great website called Superchargers Online and they had every single other piece that I needed to complete the kit. I bought from them: 03 style bracket, oil feed and return lines with the nozzle, MAF adapter plate, bracket/alternator spacer, aluminum ribbed idler pulley, and plastic smooth idler with the little flanges on the sides. Then I went to the hardware store and found all of the bolts I needed. Then I bought a new lightning MAF, 03/04 cobra injectors/pigtails, screw-in IAT sensor, and a Diablosport chip. Total cost was around $1500 before tuning for my used kit. Here is the link to the vortech manual. It has all the parts lists with everything.Vortech Manual Hope that helps.:D Definately buy it from him. Its alot of work/money but its worth it in the end. |
He got it for free?
$500 bucks. |
