rear axle drop
rear axle drop
im throwing in some 373s when i get back up to school so i have a press and what not... and im just wonder if there are any pita parts to taking out the rear end on a 99 gt solid axle. i know i gotta disconnect only a few thing shocks, rear sway, vibration damper, brakes and abs sensor, upper ca and driveshaft. are any of these a pain, im gonna b on my back so all the help i can get would be lovely. i got plenty of break away and crap. any opinions??
RE: rear axle drop
I just pulled my rear end out on my 96.
The rear abs sensors are a total pain I broke one and ended up pulling the others plug from under the rear seat.
I've heard but have not done it yet that you need to move those abs sensors in a little to pull the axles in far enough to get at the c clips.
If that the case I will try to grind a little relief in the plastic sensor case to allow the axel on the good sensor side enough travel.
The rest of it was not that bad a breaker bar and 4lb slege hammer were close by at all times.
Any questions let me know I just did this two weeks ago.
11-10-2015 11:39 AM
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
zanemoseley
09-06-2015 12:58 PM
09-01-2015 08:16 PM
