???? for those centri guys
im curious about a little more info on centris from guys who actually have them. ive always been a KB guy, but im on a budget of about 5500 so with the blower alone i want at least 420-450. lately ive been second geussin the option of a KB. i really hate sayin this but what are the pros and cons of havin a centri. i know the difference between the two and am not wantin to compare the two. i want to know what you guys like and dislike about your setups. im lookin for 550rwhp, for a DD so what setup is good.
ONE MORE QUESTION....i know with a twin screw to change boost all you need is a pulley swap, what about a centri, is it just a pulley swap or is there more to it. thanx for the help.
RE: ???? for those centri guys
I've got the P1SC. For a boost change, yes you change the pulley out. If you want 500 range, go the D-1SC route and hit it with a 3.6 or 3.5 " pulley, you'll be hitting 500's for sure. Add a Anderson Ford Power Pipe and you'll be good. I'm not sure I can find any cons with mine. I like everything about it. Install wasn't bad about 7 hrs, no oil lines to the oil pan, self contained unit, change the oil every 5000 miles(I always do it with my main oil), love the whine on it, looks great and performs great. I guess the one cons would be it's a base unit, so expecting 500 hp is attainable but it'll take longer to get there. I'm probalby opting to upgrade to the D model next year, but not sure sure. I'm going for the 500 rwhp mark first with this one, so we'll see.
I think you getting a little over zealous with your HP requests on that budget.
You do realize the limitations of every other drive train component on your car right?.
fuel dilivery, trans, forged block, rear end, possibly a new drive shaft...etc.
I get a lot of compliments on the whistles, and IMO its as noticable as the KB whine...it works as a DD and it helps alot considering i have to deal with excessive wheel hop. If i had any complaints, it kind of came to me talkin to another MF member, and i think i would go with 3.73's or 3.90's just so you stay in boost longer and maybe even pick up a tenth or 2 in the quarter[&:], other than that, since the Procharger needs re-oiling, it gets tedious but its no more than a regular routine
yes i know that, when i say my budget, i mean for the blower and corresponding components, ie: fuel pump, injectiors, dyno tune...stuff like that. im upgrading the rearend, tranny, and directly after the blower i will do my bottom end, ill just do a conservative tune to get my by untill i get the BE. ive done quite a bit of research and im not stupid when it comes this kinda stuff but i am centri illiterate. thats why i wanna know as much as i can about em before i take the big leap into buyin one.
ORIGINAL: mikev08826
by the way i have 3:90's
ORIGINAL: ponysnake99
ORIGINAL: JJ03MustangGT
whats the most you think you can get out of it????....how bout the d1sc???
NOVI 2000 FTW
