Why dumps loose performance??
RE: Why dumps loose performance??
As DanCOBRA said, the object is to reduce restriction while keeping the velocity up. Wide open exhaust is good if you're running high up in the rpm band and only care about maxing your HP (like when racing). The high engine rpms will take care of the exhaust gas velocity all by itself. The problem with wide open exhaust is that low in the rpm range the ehaust gases loose velocity. A narrower exhaust pipe (more restrictive) helps keep velocity up at lower rpms and boosts the torque output. High velocity is good because it helps scavaging. Scavaging is when the out flow of exhaust from the cylinder helps draw in the fresh charge of air/fuel.
So what does all this mean? Designing an exhaust system is a balancing act between low restriction and high velocity. How you use the car will determine to which side of the equation you want to be. For street driven (stop light to stop light) where low end torque is important, a smaller diameter pipe that keeps velocity up is what you want. But, be careful not to get to restrictive. For race applications, where you spend the majority of the time in the higher rpm's, a more wide open flow is the answer.
Makes everything clear as mud, right.[sm=headbang.gif]
ORIGINAL: Dan04COBRA
Those aren't really called dumps, some people do - but they are really called Turn Downs.
To be technical, Dumps are a pipe shaped similar to a Y with a cap, you can uncap the pipe & run a fully open exhaust.
Anyway, I don't know who said that Js 99. The only person I can think of that might have Bullets is Code?
A turn-downed exhaust vs a stock length exhaust won't make any more or less HP. If it alters anything, it might help move the TQ higher up in the power band, sometimes giving you the feeling you lost TQ overall.
Loss of backpressure=good
Loss of too much backpressure = bad. Just keep your tailpipes on there cheif
ORIGINAL: ZW99GT
code did say that, and its true. He says so, and so does my muffler guy. You will lose TQ plain and simple. Ask him. Sooo. What are yall talking about?
ORIGINAL: ZW99GT
To answer the original posters question: The only downside to turn downs is the smell of exhaust in the cabin.
If it loosens, you just need to tighten it.
If you are talking about 'losing' hp, people running straight pipes (straight pipes actually means straight piping from the manifolds back with no type of cross-over pipe) are hampering scavenging and may have uneven exhaust pulses.
Depends on the size of the pipe. If it's too big of a pipe, you'll lose power (but sound good). Too small, you'll lose power (and sound like crap).
Same goes for any exhaust you buy. You want to match the system to the engine size and build up. Stock engines need backpressure to operate properly. Race engines don't. Most factory systems, however, are more detrimental than open headers.
ORIGINAL: sleeping stallion
ok this is for turn downs or dumps but what about straight pipe no mufflers just straight i heard that looses tq tru or what r ur thoughts on that
