does a 99+digital cluster work on a 96-98?
Old 12-12-2006, 08:30 PM
300exman
300exman's Avatar
Default does a 99+digital cluster work on a 96-98?
just wondering if the cluster would work because im swapping the motor so i want the cluster too?
300exman is offline
Old 12-12-2006, 09:13 PM
slow99GT
slow99GT's Avatar
Default RE: does a 99+digital cluster work on a 96-98?
I dont think it will. I think it has to do with the OBDI.. but dont hold me to that. I am assuming that 99+ use OBDII
slow99GT is offline
Old 12-12-2006, 09:15 PM
silverstang1996
silverstang1996's Avatar
96+ mustangs all have OBDII, pre 96 mustangs(or pre 94 im not completely sure on that) have OBDI
silverstang1996 is offline
Old 12-13-2006, 12:51 AM
300exman
300exman's Avatar
yea i have obd2 i guess ill give it a try
300exman is offline
Old 12-13-2006, 04:50 AM
jmmorgan82
jmmorgan82's Avatar
i've heard it wont work because the 99+ are digital
jmmorgan82 is offline
Old 12-13-2006, 01:07 PM
droptoppony
droptoppony's Avatar
ORIGINAL: jmmorgan82
thats correct, the 96-98 are mechanical speedo etc and not compatible with the 99 up...i think you have to swap tranny's and some other stuff to use a 99-04 cluster in a 96-98.
droptoppony is offline
Old 12-13-2006, 08:13 PM
300exman
300exman's Avatar
im swapping the engine tranny and wiring
300exman is offline
Old 12-13-2006, 08:25 PM
doughboy4.6
doughboy4.6's Avatar
you are doing a swap to a pi motor ok we just did this. use your harness and ecu if not the pats system will not let you start the car. The only way you can do it is swap everything you will need the igntion and key from the car the motor came out of or the pats system will not let the car start!!
doughboy4.6 is offline
Old 12-13-2006, 08:30 PM
doughboy4.6
so the best way to do it is use your trans and harness and get a tune it is much cheaper. or you will have to go too ford and get you key programed for that ecu. and I am not sure if the wiring behind the dash will plug into the new cluster? so maybe somone that has donethe whole swap will chime in
Old 12-13-2006, 10:05 PM
300exman
300exman's Avatar
what is the pats system ? so i cant use the 2000 computer? and what about the coils that are differnt or they got the same plug?
300exman is offline
5.0muscle
01-11-2016 01:17 PM
Pyrate Dave
09-10-2015 07:30 PM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
09-01-2015 08:16 PM
Quick Reply: does a 99+digital cluster work on a 96-98?
